- Fri Nov 07, 2014 3:42 pm
#41315
Hi Jaffa
Its an electra EFI, 3 fuses, 4 relays. The fuel pump, lights and starting/ignition circuit are all fused I believe. Not sure if the reg/rectifier is? Anyway, I don't have time to fix this at the mo, so the helpful man at the nearby motorcycle auto-electrics shop is looking into things for me. No fuses blew, no relays burned out, but wires melted (wires which are fused!!!! only a few inches away from where they burned through!!!!). His initial guess was charging... but I suspect a damaged wire has shorted. The glass fuses on these bikes are a joke, and the fuse holders are so far from waterproof it is unbelievable. They corrode soooo quickly. Anyway, we will see. I just had a call from the electrician, but missed it... update to follow.
