- Wed Oct 29, 2014 9:17 pm
#41194
Hello ..... oil consumption can really be only be one of 3 things. Oil leaks, oil out of breather or burning oil. Leaks and breathers problems are easy to checked which leaves burning oil. Oil can only get into the combustion chamber by passing the rings, down guides and through the valves, leaking pushrod seals or porous head castings. Porous casting can be checked with some of the proprietary testing kits. The pushrod seals can be a bit of a problem but if they are leaking it is general for the oil to be blown out rather than sucked into the cylinder. So ... sorry to say that this indicates something in the engine build is not to spec. A number of things it can be. Piston clearance, check the barrels have been bored parallel, it is quite common to grip the barrels by the exposed liner at the bottom of the barrel which produces a tapered bore. Also if you are using aftermarket piston use the suppliers figures (forged pistons in iron barrels have large clearances and I have know companies boring for these have ignored the figures because they "feel" they are to big. Ring fitting and gaps, again if you have aftermarket rings the clearance and fitting or these is often different to OEM workshop manual figures. Oil control and taper (scraper) ring design do vary between supplier. Just because they are not marked top does not mean there is not a top, look for a taper or a step. Valve stem to guide tolerance, valve guide fit (quite uncommon this but I have seen guides fall out when dismantled). There is always a question of valve seals, my view is they are just covering up the problem. In my experience the only answer is to re-check everything and when you have checked, check again. Richard
