By JTL
#40486
I solved my carb problems with a Mikuni TM32. I'm not really reving beyond 4000 rpms, so can't tell if it will cure misfires unless the problem is a too lean fuel mixture. A 32mm carb is the carb size to choose. It can feed the engine all the fuel needed. The TM32 is easy to jet and works very precise to any throttle moves. Best upgrade I have done in a long time. regards Jacob
