- Sun Sep 28, 2014 9:33 pm
#40124
managed to get back to the charging problem over the weekend.
for jaffa90, the bike has electronic ignition so obviously does discharge the battery just running, even without lights.
fully charged the battery reads 13.2 volts across the terminals but left for a while has 12.5
24hrs later it has 12.5 v
back on the bike, the reading was 12.46 v
ticking over it reads 11.85
at revs ( as much as i would want unloaded ) it reads 12.06
after these tests on the bike it reads 12.27
conclusion to me seems to be that the battery is in pretty good condition and accepting charge.
as the alternator seems to be only producing 3 to 4 volts with revs and less than 1 at idle it would seem likely this is my problem, seems to be putting very small charge into battery.
had the cover off today too and all seems tight and clean in there,lock nut on the rotor is tight and everything firm with no play and wiring seems all in tact.
so presumably the only way forward now would be a new stator? i presume its unlikely the rotor would be the problem?
its the first time i have looked at the alternator and i expected there to be a visable gap between the rotor and the stator windings but they seem to be making contact all round, is this right? it must have always been like this as there is no way it could be any other way. each coil winding is actually making contact with the rotor. unfortunately it is all learning curve for me so i may be interpreting all wrong !
