- Sun Aug 31, 2014 12:06 pm
#4103
Greetings from the Kingdom of Denmark!
I own a 1957 RE Bullet - 350 cc - 6 volt.
Prior to riding it 4 months ago, there appeared to be little charge to the battery. However, then on a fast trip: 60 mph plus... it started charging and when I returned, the red cord i.e. negative (with Positive being the ground) had melted just at the battery connection and the battery was dead.
The fuse of 25 AMPS had not worked!
Upon checking for apparent shorts in the electrical system, I installed the new battery and a 15 AMPS fuse and connected with Positive to ground.
After 15 seconds, the unit holding the fuse started smoking and I quickly took the connections off...
What can be the problem?
The charging relay not functioning or are we talking about a malfunction in the stator/rotor at the primary drive?
I truly appreciate your ingenious comments.
Good Vibrations to all!
