- Sat Aug 16, 2014 4:59 am
#4052
Morning.
The bike is a 2004 Royal Enfield 500 Bullet, fitted with electronic ignition.
On the way home the other night the bike was running well but from nowhere the bike just stopped. I pulled over and noticed that the amp meter was showing no amps, I checked the lights and horn and I had nothing. I called my father out and he arrived with a new battery, we connected it up and the amp meter went straight to the left and showed full minus amps and the fuse then blew. First thing I did was to check that we had connected the battery right and yes we had. I tried a spare fuse and that did the same. I called Carole Nash and they sent out a rescue track and that got me home. Last night after having the battery on charge I put it all back together, put a new fuse in and the same thing has happened the amp meter shows full minus amps. I have checked most of the wiring and can not find any shorts.
Anyone got an idea what it could be.
Thanks Eddie.
Thanks Eddie.
