By bikerp
#3866
Hi all,went to kick my bullet up today and kickstart not engaging,as in not turning the engine over.Anyone any ideas?Thanks.
By Bertie the Bullet
#37257
I'm no expert in the inner workings of the gearbox but first thing i would check is that the clutch isn't jammed in the 'lever pulled' position if you get my drift, as this will disengage the gearbox from the engine.. good luck sorting there problem.
By dennis t c
#37259
When I had this problem it was the pawl in the gear box, it took two hours to fix by a R E specialist mechanic
By Paul M H
#37260
If its not engaging at all with just no resistance its probably just the kick-start pawl & small spring needs replacing not too hard job parts available as a kit on this site.
