- Sun Jun 01, 2014 3:05 pm
#3705
Noticed the the horn on my Sixty5 had stopped working, so I set about adjusting the tone screw at the back, only to find my screwdriver sparking against the timing cover! The horn then worked for a while, then stopped working again, and the ammeter showed a full discharge (short?) when the button was being pressed. The horn sparks accross the earthed screwdriver EVEN when the horn button is not being pressed! (When the ignition is on). When the horn does work, the ammeter behaves normally, yet the body of the horn will still spark against the screwdriver. Is it likely to be just a faulty horn, or is there something else going on? (Even if the horn is faulty, I wouldn't have expected it to be "live" like this when the button wasn't being pressed!). The rest of the electrics are still working normally.
