By devon john
#3607
i asked a question a couple of months ago asking if the later disc brake fork legs would fit the early type forks (2007) well yes they do as i have just fitted them with a disc brake set up.
the only thing i need now is the speedo drive as this is different than the drum brake! which i have just ordered for are host.
#35702
Thanks John, useful info. We (I) always suppose that the Indian bikes will be updated the easy way, that is just modified rather than totally changed but it's good to have that confirmed! REgards, Mark
By another Allan
#35707
Hi John, just for clarification, when you say 'legs' are you referring to the complete unit (i.e. stanchion, slider, spring etc) which you have found will fit the earlier casquette and bottom yoke, or do you mean the later disc sliders will fit the earlier stanchions and internals?
By Nettshubby
#35710
If this works it should show my 2003 Sixty5 with disc conversion. (I didn`t do it, by the way!)
By another Allan
#35720
Thanks Alan & John. I still have to work-out whether my (much) later one-piece sliders, without the separate spindle clamps, will fit my 2003 stanchions. When I have the chance, the spanners will be coming out!
