- Thu Apr 24, 2014 8:17 am
#3543
One for the EFI or the lecky wizards...
I pull my front brake lever and often (more and more often recently) the EFI warning light trips on, cutting off the engine if it is running (i.e. injector is switched off). If the engine is not running, but ignition is on (when testing!) the fault stills trips the EFI system, but it actually seems to kill all electrics off on the bike becuase things like the neutral indicator light trips off too.
What I tested: I unplugged the front brake light switch and there is no longer a fault, but it occasionally trips out if I push the rear brake lever (this also happens when everything is connected, just less frequently).
Any ideas on what to do, look for or what might be wrong?
