By jenks
#3577
i have plastic oil pipes connecting to me tal pipe held by jubile clips, what type of tape can i use
to tighten the fitting ?
cheers
jenks
#35354
Hi JENKS------------any chance of a photo to clarify your situation please ?? ( It's very easy to do.....)
By jenks
#35356
Hi Alan r ,can't provide photo, it's a plastic pipe connecting to a metal stub on the oil tank on a classic bike. Need to seal clamp connection as plastic has stretched
Regards
Jenks
#35357
Jubilee hose clip, get them from your local car spares shop/motor factor.
By Exile
#35365
Whew.. complicated. Your options are many:
1. Tighten jubilee clip...
2. Buy a new piece of plastic tube...
#35371
Hi guys------- Sorry but I'm still trying to fathom out where these plastic pipes ( or pipe ) are and what is this "stub" that's mentioned ??..I've 2 Classic 500's and don't see any.......Mind you, I've just had an "Invitation" from HM Gov. to "Apply" for a State Pension ( Yes, I'm 65 this August) so you could put it down to}-- Auld Fartybagz Syndrome !!.... JENKS, I'd be interested to know why you can't post a photo ??..... If you yourself can't ( no camera or no experience etc.) then a relation or friend could post on your behalf........... One picture, 1000 words etc....
#35379
Alan, I think he means the breather.
By Davie Hall
#35381
Heat the end of the plastic pipe in a cup of boiling water with the hose clip attached, slip it onto the stub while its still soft then tighten the clip. But do as someone suggests fit a new pipe of pipe first
By Gwilly
#35382
Nip down to your local tropical fish supplier, they usually have a large supply of various size plastic tube...
You need a short piece of tube with an internal diameter that fits tightly on the stub and with an outside diameter that will fit tight in your existing tube..
Creating a sleeve on which you tighten the clip...
