By val
#3510
Bet you have been asked a 1,000 times before,08 leanburn electra,castrol 15w-40 semi or castrol 20w-50.thanks val.
By Leon Novello
#34942
Any mineral motorcycle oil will be fine. Particularly, don`t use semi or full synthetic if running-in a new engine or new parts in it; they have friction modifiers which make them more slippery so it will take ages to run-in new parts. New vehicles which recommend synthetic are usually run-in at the factory to avoid this problem. So you can drive them at normal speed from the showroom.
By jaffa90
#34943
Lean burn engines run hotter, synthetic oils can handle this heat better,20/50 mineral oil is a no no. Make sure you use motorcycle oil and not car oil.
By Midge
#34944
Click on 'Catalogue on line button', go to page 11. Mr H knows best!
#34945
Whatever it says in the riders handbook, perhaps ??
#34951
Jaffa and Leon, I thought the main difference with a motorcycle oil was that they are formulated to deal with a wet clutch.
As this is not the case here why would not a car oil do the job?
There didn't use to be such a thing and we managed well enough.
By jaffa90
#34952
Your right PeteF, bike oil only is for wet clutches.
#34963
Interesting link but it was written by an oil manufacturer.
Oh dear, my cynical side seems to be showing again.
