- Fri Apr 04, 2014 5:21 pm
#34565
I have a reverse cone megaphone on my 500 classic. I use 125 main jet, and a different needle jet as per the catalogue. It did not go too well initially, and when I took the mega apart there was nothing left inside, just a few bits of wire which had secured the original matting in place.It was also very noisy, not neighbour friendly at all
so I filled the space between the perforated tube and the outer shell with Acousto-Fil material, it's a bit like fibreglass but it is a woven material, and should stay in place. This set up does make a fabulous sound, the bike can also be ridden very quietly if required, but still has a nice fruity bark when I open her up! I think the carb set up, which is the standard 500 Micarb, is about right.
