- Tue Apr 01, 2014 6:21 pm
#3444
Help, I am a bit confused. I have a 1990 350 Bullet and am planning on an engine oil and filter change.
I notice for a 2000 yr on 350 Bullet there are these bits...from the online parts book:-
Drain plug - 500140;
Copper washer for drain plug - 144846;
2x Drain plug and filter - 140052;
2x Copper washer for the two drain plugs and filter.
On the 1991 yr 350 Bullet there are just these bits:-
Is there no sump drain plug on the earlier models?
How do you drain the sump on the earlier models?....I cant look coz I am away with work and the bikes at home.
Oh, and if the engine oil filter is changed how or what tips to top that cavity up with oil? Pour some in where the 'tappet adjusters' live after taking off the cover - so it doesnt run oil less until the filter chamber has some lube in.
