- Sun Mar 16, 2014 11:08 am
#3391
Off topic, but here's the thing; I have a diesel people carrier that has stood for several months. I am having trouble starting it as the battery won't seem to take a charge; I don't know what Ah it is, obviously very many, but the 8 amp charger I am using should do the trick. One solution would be to try a jump start, although the two hatchbacks I own are not quite up to the job.
I am wondering whether it would do any good to connect the Optimate charger for the bike. Obviously it would take months to recharge the battery like that, but it also has the function of reviving knackered batteries, and this works by delivering a high voltage rather than a high current.
Any thoughts? I expect I will end up replacing the battery, but it will be expensive and the car ain't worth that much!
