- Wed Mar 19, 2014 7:56 pm
#3402
May be old age and stupidity but this little tale may be of value to others similarly afflicted? RE Electra X based sidecar outfit failed to start after a brilliant 2013. (See other post) So after suspecting dirt in the carb and its complete strip down and clean and replacement with a spare carb, a knowledgeable forum member suggested a new plug. It worked. The spare carb leaked fuel and despite screwing down drain plug with no effect realised that the float valve was leaking. Decided to refit original carb which made things worse with very weak mixture banging and popping and generally rough. Thinking of replacing it with spare carb with repaired float valve when I noticed a large O ring on the bench - yes you have guessed it I missed it off when fitting carb - fitted properly to the manifold all working well now. BUT................
