By grahamwalker
#3386
Does anyone know where I can find a template or mask to paint a panel on my tank its like a D shape but longer?
thanks graham
By simon
#34007
I just free formed the ones I've done. It's generally easier than you think. For the tight curves cut thin lengths of making tape. You can see my efforts in this bunch of pictures and they worked out all right. It just trial and error.
#34011
Lining tape does a great job I just painted a chrome tank, masked out the chrome, painted it and looks fantastic
By grahamwalker
#34013
Yes thought that just wanted them the same each side, being a keen scale modeller I have plenty of tape in diff widths
#34014
Graham you will have to cut a pattern, might take a few goes, stick it to the tank, scribe around it and then remove the pattern and mask up to the scribe line, best I can give you
By simon
#34018
You never get to see both sides at once so complete accuracy isn't that important though.
By devon john
#34022
lining tape is made of plastic and in different widths , its very easy to pull around the tank Don't use masking tape as it is not so sharp an edge.
#34027
Look in Accessory Catalogue under Transfers, then Tank EFI. That what you're looking for?
