- Sun Mar 09, 2014 6:03 pm
#3359
Hi all , I have a problem with my new to me electra X. When I switch the headlight on dip beam is very dim and main is normal. On checking both bulb filaments are dimly lit when on dip .l have checked the left hand switch, disconnected the green wire and it goes out as it should and main beam still functions as normal. Ieven put a direct feed to the bulb from the battery with the dip beem feed disconnected andboth filaments still light up. Anyone have any ideas where the problem may be . Just noticed that the brake light is stuck on, I disconnected the rear light in case that was causing the fault but the headlight still has the same problem. Any advice gratefully accepted
Cheers Dave
Cheers Dave
