- Thu Mar 06, 2014 9:17 pm
#3342
Hi all,
First time posting here, and I'm sorry to have to start with a problem.. I'm also completely new to Enfields (and serious motorcycles in general, most complex ride I've had was a Vespa), so I'm fairly confused right now.
I just got a '04 Bullet 500 sixty-5, which worked beautifully for 5 days, until today. This morning I started it with the electric start as usual, and the engine immediately went full-throttle-mode. Kill switch didn't kill the engine, turning the ignition off only lowered the RPM slightly, but the engine kept on running. I had to stop it by slamming the brakes and releasing the clutch slowly into 1st gear, thus stalling it. I had to get to work, so I left the bike and returned later.
This evening I checked it again, and the exact same thing happened, I killed the engine by turning the fuel supply off. I also noticed the weirdest (for me) thing, the throttle twist grip is now stuck in "reverse": its resting position is now in what you would say full-throttle, ie all the way turned open. So that might explain the engine going in very high RPM. However, turning the twist grip down seems to increase the engine revs, instead of lowering them. Also, if I "close" the throttle a bit and release the grip, it snaps back to the full throttle resting position. Finally, when I at first gripped the throttle grip this evening, something felt a bit "wrong", like a cable was stuck somewhere. As soon as I opened it a tiny bit, it snapped to what I describe above and it's been like this ever since.
Being new to all this, I can honestly say I have no idea what's going on with my bike right now.. That's why I turn to you guys. Any input would be appreciated.
Cheers,
Kostas
Cheers,
Kostas
