- Mon Mar 03, 2014 10:31 am
#33725
Denis C, well I sort of forgot, my last engine was a 1924 Lister with ML- MCK magneto which I had to get from a parts jumble. Saw the hen's teeth MCK, grabbed it quick and gave the sprocket a flick. Screamed loudly, bought it, and it had worked fine ever since! I think there is a capacitor in there some where, but i only set the timing and points!
John-L, If i'm explaining it, chances are it will go round and round until even I forgot what point I was trying to make. therefore 'hypothetical' sinks lower and lower until it becomes 'hypo-pathetical', or 'beneath pathetic'.
CONCLUSION (worth a try...)
Remove spark plug, leave HT lead connected to the top of it, rest body of plug against engine but so that you can see spark plug gap and turn the engine over. If you see a nice blue spark then put plug back in, Jump in the air, kicking your heels together whilst shouting "Scroombana", get on your bike and ride in the blissful ignorance of how it works, but with the happy knowledge that your bike works well!
"Turn right four times, that brings you back here, then ask again!"
REOC 15084
Tabellarius de verbis. Ostensor gaudium
