- Sun Mar 02, 2014 1:23 pm
#33490
Coils and how they work.
Ignition coils have two coils in them. the amount of turns of wire on the coils, determine the change (if any) between current (amps, milliamps) and voltage.
Few things to know,
coils (and transformers) only work with changing or fluctuating voltage like alternating current (AC), or with Direct current (DC) IF It is being switch ed on and off. (Like bullet points opening and closing)
Ratio of turns on coils equals ratio of input/output voltages.
Power going into your coils from battery and points, we call primary winding.(well, I going to for this explanation.)
Power going between coils and spark plug, we call secondary winding.
Here is a hypo-pathetical coil... 12 volt systems.
If it had 10 windings on the primary (points) coil and 10 windings on the spark plug coil, and you put 12 volts across it, you would get 12 volts out (not enough for a spark, but keep reading)
If it had 10 windings on the primary, and only 1 on the secondary, you would get 1.2 volts, but also ten times the current in amps. (Think of mig welding)
If it had 10 windings on the primary, and 100 on the secondary, the secondary is ten times bigger so then you get 120 volts!
Ditto 10, Ditto 1000, Ditto 1200 volts
SO, For the 1 to 150 ratio as JTL said above,
ditto 10, ditto 1500, output, which is 12 volts times 150, giving 1800 volts. Not enough yet...
as long as the ratio of turns is the same, the number of turns can be changed to get more or less current flowing, therefore taking from above post,
30 turns on battery and points coil, 4500 turns on secondary to spark plug, gives you... 1800 volts again, as it is still 12 volts times coil ratio of 150
SPARK PLUGS NEED 10,000 to 20,000 volts to work well, This is why It not nice to put a finger there
We will say 12,000 volts for ease. That is 1000 times larger than the 12 volts we are putting in, therefore, the number of windings (Turns) on the secondary coil needs to 1000 times the number of turns on the primary.
ditto 10 turns, ditto 10,000 turns, gives 12,000 volts, because difference in coils (10,000 / 10 =1000) times input voltage (12V) 12 * 1000 = 12,000 volts.
(Why, oh why did I start this? my bloody head is going round now!)
Search for this post in future, I never repeating it.
Wailyback
REOC 15084
Tabellarius de verbis. Ostensor gaudium
