- Sat Mar 01, 2014 9:45 pm
#33457
Norm: The jets are all brand spanking new. I rejetted after fitting the new S&B air filter, which just about everybody here said I should because the engine would otherwise run lean and the guy from Hitchcocks helped me with that.
It ran (sort of) OK after that but it is, and was, running rich. If you don't count replacing a torn manifold rubber, which should have made it leaner anyway, as critical, then how else do I get it to run a little run a little more lean? Playing with the air screw and throttle stop doesn't cut the mustard.
Could it be, that the fuel mix that the PAV (now removed) was 'stealing' from the total fuel supply is making a difference now?
I will move the needle stop back to where it was. If, as you say, it makes no difference, then I have gained nothing there anyway.
Pony, another forum member, is having the same problem as I, having done the same mod as I did.
1. Fit S&B filter.
2. Rejetting the carb. as per Hitchcocks recommendations.
3. Remove the PAV.
Results in both cases are the same. Rich mix.
We're both stumped.
1. Fit S&B filter.
3. Remove the PAV.
We're both stumped.
I didn't buy the bike to add years to my remaining life. I bought it to add life to my remaining years.
Exile.
Find me (and Thumper) here: http://thumperdiaries.exilesplace.dk/#home
Exile.
