- Tue Jan 28, 2014 3:08 pm
#32463
Just a thought... although this is almost certainly NOT the case for you Harris... but a chain which is too loose can also strip a tooth or two. It wouldn't strip the whole sprocket though, unless it was one tooth at a time over a long period of time!! The loose chain can strip it by not engaging properly with the teeth, and slipping back and forth in the tooth - I have lost an occasionaly tooth that way.
Probably doesn't help here, but getting the chain tension right is important both ways. How did you get on with your claim?
