- Thu Jan 16, 2014 4:27 pm
#3110
After having fitted the S&B filter and shroud, I thought the carby looked a bit unsafe simply dangling on the rubber hose between the cylinder and itself. It jumps about when I drive on rough roads and the top of the carby was knocking on something, probably the frame or the underside of the tank. I could hear it when I rocked the carburettor by hand.
Having once done a bit of fabrication, I decided to make some sort of supporting bracket for the filter side.
I got some thin aluminium strip from the local hardware store and got to work with vice and pillar drill. Here's the
result..
The top end fits under the tank retaining bolt and the tang at the bottom fits under the jubilee and over the rubber end of the S&B.
The carby is set solid now with support at both sides..
Sometimes, I amaze myself..!!
result..
I didn't buy the bike to add years to my remaining life. I bought it to add life to my remaining years.
Exile.
Find me (and Thumper) here: http://thumperdiaries.exilesplace.dk/#home
Exile.
