By Foz
#3131
I'm trying to find out if I have a E5 Or a G5 it's on a 10 plate
it's a Electra efi I can't seem to find out any were and are parts interchangeable
(Front fork bent)
By Michael
#32044
As far as I am aware E5 is the US name for an electra and g5 is for a bullet. There are some differences I believe; gearbox sprocket teeth, rim size are two. But dont quote me on that! The online catalogue should help you check interchangeable parts though.
By Michael
#32045
AND I think the front ends are a bit different. The G5 has a deep mudguard, the E5 electra has a skinny rubbish thing.
#32047
In Aus the G5 was similar to the old Electra X but with the UCE motor. It had side covers instead of tool boxes, stupid sausage boxes and only half a front mudguard. I would take a stab that the fork tubes are the same but the lower legs are different depending on the type of mudguard fitted
By Chevy
#32049
Fox, The E5 is the standard painted Electra EFI made from about 2008. The G5 is the deluxe version of this and has chrome mudguards and tank etc
Chevy
By Foz
#32069
Cheers guys It sounds like I've got E5 so the next drama our hoasts are out of
compleat left forks so would the classic fork set on the used part fit my Electra
#32072
Foz,
Do you need the bottom leg or just the tube, if you need the bottom leg you need the right one because the one you have , the mudguard mounts up high on the lower leg with 2 studs? This is where Enfield stuff now goes into very murky waters
By Foz
#32074
I need both pArts as they have a slight bend were they join
#32075
Foz, if you are in the States and our hosts can't supply, you could try Nfield Gear I believe they are in the States
By Chevy
#32076
Either the E5 or G5 forks will fit, the legs are the same, the difference is just down to the finish of the alloy sliders so if there are no E5 forks available fit the G5, they will fit straight on.
Chevy
