- Mon Dec 30, 2013 4:48 pm
#3057
Hi again gents, while the front wheel was off I thought I would check out the rusty wet stuff running out from under the front suspension covers ( Bertie has the metal type covers that cannot be moved or removed until the stanchions have been removed ), so I have removed the bolts that hold the indicator arms and clamp the stanchions to the steering head, also removed the big screws in the top of the nacelle, looking down the hole I can see a hex shape hole and the spring ( no oil ), I have some questions..............................................................
1, Can I assume that I need a big Allen key to undo the stanchions from the nacelle ?
2, If so please can someone let me know the size the hex is ?
3, Will there be any more unusual tools required to change the oil seals ?
4, which fork oil is best for a nice soft comfortable ride ?
Thanks again gents.
Thanks again gents.
