- Sun Dec 22, 2013 7:30 am
#3027
Hi Guys
I have a 1996 twin-plugged 535cc Bullet with twin lead coil and have long thought the advance mechanism (the second one I have tried) does not give a proper advance rate because (a) the acceleration rate is minimally changed and (b) the new downpipe is browning along fully 50cms despite the strobe-tested correct max advance (28deg) from a reduced-movement A/R mechanism (between 9-10degrees). In this regard, I have also taken advice from this message board and added stronger A/R springs and reduced the weights to ~10gms but still don’t feel it is advancing suitably.
I am considering replacing the A/R mechanism and points with a Boyer. But which one - the standard Mk4 or the Digital? The Digital one apparently gives a better advance curve for the 500cc.
Can anyone suggest what the right one is?
Thanks and compliments of the season to you all
