- Mon Dec 09, 2013 12:58 pm
#30773
I think JS has a good idea here, just think for a moment, the first time you find you have white metal in the rockers is when something goes wrong.
Example the pump worm strips due to blockage… Would you perhaps see those telltale shiny bits in the glass filter if you left it in…?
Might just give you a heads up to impending bearing failure before the big knock tells everybody…
Filter could be cleaned on a service/oil change..
