- Sun Dec 08, 2013 2:41 pm
#2992
For you new members and those who remember my thread on the oil circulation sight glass mod here is an update.
I have now covered over 2500 miles on the bike since i fitted the sight glass and there seems to be no trouble with it so to recap on how I make these.
You can buy the basic sight glass off of EBAY, there are two types. The first is for those of you that are not so technically minded and can just simply be fitted with two hoses and clips. The second one is threaded both ends and come with adapters, alas the adapters are only made of plastic but can be replaced with a brass air connector that can also be purchased on Ebay, the total cost being less than a tenner.
The part of the adapter that is for the hosepipe is cut of and the return oil pipe is cut and soldered into the adapter. If you have a none electric start bike you will need to buy an electric start return oil pipe and banjo. The pipe can then be fitted, bent down and then up
to allow fitment of the sight glass, being careful not to kink the tube. The best way to do this is to use a wooden dowel in a vice to bend the tube round.
I did make a video on youtube showing the sight glass in operation.
Copy and past the link.
http://www.youtube.com/watch?v=f0QGZ6_wFEw
Hope the photo comes out this time.
