- Thu Dec 05, 2013 3:49 pm
#30717
I notice from your photo It appers to be the brackets that are breaking not the indicator stem. I had exactly the same problem with those thin brackets on my work bullet. At the front I drilled the headlight casket and mounted them on there which also gives much better visibility as well. On back ones I made me own L shape brackets that mount on the bolt at the top of the shock/frame mounts.
