- Wed Nov 20, 2013 7:49 pm
#30465
Hi grusome I have been contemplating extending a bullet swinging arm as next year I,m going to mono shock my 500 bullet , I'm contemplating either making some slugs up to slug the extra length with tubing of the same diameter and also filling the tube where the slug runs at various lengths this sounds complicated because it is although a good welder can do these things although I'm thinking I might make a box section swinging arm I see someone mentioned BHS mag their have been loads of bullet bobbers in 100 0/0 biker too,I suppose that by lengthening the swinging arm you can make it wider to take a wider section rear tyre although I'm sure our host used to do a wider swinger for trials bikes anyway good luck Paul.
