By DavidB
#2907
Can anyone please tell me where I can get the corretc grease nipples for my Ehfields. I have 3 RE models, all with girder forks that need grease nipples. They need to be quite short threaded so that they dont rub on the fork spindles. I am not sure what thread they are supposed to be. Any help on what type and where they can be sourced would be appreciated. Thanks
By Paul
#30397
Hi, Hitchcocks should have them, I've bought them from Allan before for my WD/CO. He should have the spark plugs you nee too.
It is so important to support our hosts, even more so if you have an early Redditch bike. Without good support they wouldn't be able to remanufacture so many impossible to find early parts.
Cheers
Paul
By guru
#30399
David, yesterday purchased half a doz stainless greese nipples from Lightning Spares, (170 Cross St, Sale, M33 7AQ) they are 1/4 BSF but i don't mind tapping out the hole a touch, 2 quid a peice not bad considering had tried stafford show and Garstang auto jumble with out any luck before hand, there fone N0 is 0151-969-3850 or www.lightning -spares.co.uk
Cheers
By DavidB
#30406
Thanks for your help and advice. I will follow up the leads beginning with Hitchcocks
By Leon Novello
#30420
If Hitchcocks can`t help, try the Morris Minor Club; those cars had so many grease nipples to service, the car came with a grease gun as part of the tool kit.
#30426
Yes, I can vouch for Leon there as have owned 4 variants down the years..............Also, why not just put "grease nipples" on E-Bay ??
#30431
I must admit these grease nipples are a pain to get out here, I need some more I used the last I had on the Super Meteor the other day
By Paul
#30441
Although fitted with 'grease nipples', some girder fork need oil lubrication rather than grease. You can get low cost oil guns for applying oil via grease nipples. Worth checking with the original workshop manual. I always oiled my WD/CO girders.
Cheers
Paul.
#30451
I ALWAYS grease my nipples-------------------------- but HEY !!, that's just the way I am !!
