- Sat Nov 09, 2013 3:58 pm
#2888
Hi guys,
It seems my 1951 Bullet has a bit of an oil problem. She wet-sumps a lot (probably more than what could be considered “normalâ€) but the pumping oil out of the breather ceases after a bit when she warms up a little (or else she’s then pumped out whatever has drained into the case I guess!). Once she’s completely warmed through (so after a couple of miles) there seems to be a fairly constant fine mist of oil out of the breather and she is also then burning a fair bit of oil (blue-smoke-syndrome).
The furthest I’ve ridden in one ride is therefore only around 15 - 20 miles as I’m obviously concerned that the breather could be blowing oil on the tyre (not ideal…..!) or as she's obviously burning oil etc something needs to get sorted. After buying her this time last year I had the mag reconditioned (starts 1st kick now), new brake shoes, tyres, cables, clutch, exhaust valve and top end checked and did a few other jobs like carb cleaning, new fuel tap etc etc so I spent a fair bit just after purchase when in theory she was all good to go with nearly 112 months MOT....... The guy who did most of the work (Enfield specialist) reckoned that the main phosphor bearing needed replacing as oil was perhaps passing through it and not properly being pumped-back to the oil tank.
Unfortunately I’m in no way competent to do a bottom end rebuild myself unfortunately ("A man's got to know his limitations" as Clint Eastwood would say) and he thought it would be around a further £800 job (so I’m thinking £1k after a few “extras†are found to be done as the always are) although he did say he’d do a reduced labour rate for me over a winter. Some advice please from all you all would be really appreciated. Does that sound like the likely problem and solution? If so, does the cost sound about right too? Incidentally, when hot she does seem to run pretty fast too – manual advance/retard of course so I’m wondering if this is currently over-advanced?
Thanks for any thoughts!
