- Sun Nov 03, 2013 10:58 am
#2871
So after fitting the LED lights on the mirror mounts and fixing the carburettor ( the needle had come away from its clip and was floating around, still not sure how Bertie ran at all), finally got out for a test run yesterday, Bertie is running sweetly again but found that the LED's and all the other lights tend to flash at the same rate as the engine revs, this improved as I rode, maybe the battery was a bit low to start with or maybe thats just Enfield for you, downside was that one the LED's stopped working after about 2 minutes, could be a loose wire or it could have blown, haven't had a chance to investigate it yet. but then for £1.84 a pair what did I honestly expect, good job I have some spares!
