- Tue Oct 22, 2013 8:04 pm
#2839
I am considering converting my 500 bullet 1993 to cdi ignition using the Electra flywheel magneto and cdi box.It looks like I will have to change the drive shaft on the crank on the drive side to the Electra type part no 145430/B.
I will either use the Electra cdi or an aftermarket cdi with ignition advance programmable control(such as Zeeltronic).
Has any one done this?
Looks like I will have to replace the clutch cover as well unless I can use a spacer ring.
I would appreciate any feedback.
Thanks
Thanks
