- Thu Nov 28, 2013 6:04 pm
#30602
The Machine Mart one is similar to my machine. Not the best in the world but how much use is it going to get? It won't be able to run for too long without cooling down either. It welds up to 5mm which should cover most jobs and in fact, if you pre-heat the job, it would probably go to 6mm. I pre-heat a lot and am surprised at the penetration I get on quite big lumps of steel. I got a really good weld putting a 5mm bracket on a 12mm solid bar the other week which is far more than machine should do. People often fail with welding by not prepping the job first which is just as important as your technique. An angle grinder is almost essential to prep welds and to grind off when (if ?) you overdo it. Tip #1- keep it in a dry place so the wire doesn't rust. If it does you might as well chuck it out and get a new spool. #2 change the tip and shroud fairly regularly and the wire tube occasionally depending on use. #3 don't bend the wire/gas/electric carrying tube to far on these cheap machines. #4 clamp every job before welding - if you try to weld without it WILL fall over. #5 pick up bits of waste welding wire - it's great stuff for getting into tyres.
Classic C5 Euro 4 at the moment.
Also CBf250.
