- Thu Oct 10, 2013 5:28 pm
#2784
Hello all, I wish to add a relay for wiring in accessories,the plan is: wire from ignition to activate the relay, wire direct from battery via the relay to a small fuse box that will be fixed in the tool box, accessories powered from the fuse box, this way I can add my heated grips, 12v socket, and anything else i wish (im thinking some LED spot lights for the dark winter months), this will also help to tidy up the wiring a bit. The bit im not sure about is what type of relay I need, I assume there are different types, any help here would be appreciated. Thanks
