- Wed Oct 02, 2013 5:34 pm
#29151
Frank ... since my last post I have done some checking on the wirering. The ground wires should all be ok, maybe except from one: the original Indian ground wire from the battery to the frame. This is now altered and re-done with the others (more paint removed and electrical smear used). Some time ago I had an accident with a short melting some of the wire insulation (wires to the ac regulator). I had to substitute parts of the wirering. I guess I did a wrong hook up of the ac regulator, but the bike has been running and the headlight shining, so I took everything for being ok. The rear light filament blowin' (not the brake light) may be caused by a bad ground. After a little re-wirering I will do another test and post the results... Norm, you make the conversion sound very simple, and I believe it is, but this thing with the relay and the four different wires with different colours sort of confuses me. I need to do a diagram to litterary get the picture; I'm a very visual person and know next to nothing about electrics. The 4-pin 30/40 watt relay you mention, where do I buy this this. I'm living in Denmark and stuff are not as easy to find here as in other parts of the world. Some stuff is only obtained on the net. Well. I'm getting more and more confident in doing the conversion. The practical part of it will be a piece of cake. I just need to understand how everything is connected... I really appreciate all input on this matter... Jacob
