- Mon Sep 30, 2013 7:53 pm
#2733
Hi all (and especially the electrickery wizards)... I have problems with my electrcals. Just performed the Bullet electrics test as our host has described it in the technical notes. The bike is a 2003 500cc Indian home market model (ac/dc), and I have some problems with my ignition (not the timing; just ignition) and blown bulbs at the taillight. It started with bad starting, so I thought it was time for a new battery, but my problems continued. Then I did the test. The alternator produced 45 Vac at half throttle, so this part should be fine. From the regulator/rectifier I had 11,64 Vdc at half throttle and it should be between 13 and 14,7 Vdc. This means something is not right. When measurring the output from the ac regulator I had 0 V. This also means something is wrong, and maybe my problems with the ignition are two faulty electrical components?... Will the cure be just to buy the two new parts? Should I go for a Boyer Powerbox? Or will the A Reg One solid state regulator/rectifier for a single phase 12V system do the job? I want simplicity and reliability; two things the Indian parts has not yet given me... all advice on every aspect of my electric misery are most welcome... Jacob
