By PO51UHD
#2647
Hi again folks. Timing adjuster sorted (thanks Mark), next job is tightening things as I reassemble. I have the manual from Mine Host, but can't find any torque settings in it. Can someone please point me at a list of these? Initially I need timing sprocket torques but will eventually need head nuts, d/s crank nut, alternator rotor, clutch centre etc etc...
Thanks, Stephen
#28181
No torque values were published for these so you'll have to use your skill and judgement! However, 23foot/pounds has been found to work for heads and bigend bolts. When doing heads use our Host's hardened steel washers, they are in Accessory Catalogue for the Bullets. Clutch can use the new Nyloc nut for confidence. Use Loctite on alt rotor bolt. The rest is feel! REgards, Mark
By PO51UHD
#28182
Mark
Thanks again! Good tip re head washers too… it seems we're on similar missions: where are you located btw - anywhere me in Cheshire?
#28185
Yes, l have a Connie and lnterceptor on the go, the Con much nearer completion! I'm near Silverstone in Northants so not a million miles! You can contact me on mumforduk(at)hotmail(dot)com if you need help. REgards, Mark
