- Mon Aug 26, 2013 3:16 pm
#2592
Hi folks, I wrote a few months ago about problems I was having with the ignition on my little Enfield & a few of you contacted me with suggestions none of which unfortunately resolved the problem. In the end I have managed to get the bike to run, although very poorly with the main problem being that if I have the ignition advanced to where it should be (5/16" BTDC) I loose all of the spark as the coils are then in the wrong position for the magnets in the flywheel. If I retard it some 116" it regains its spark & if I go another 1/16" the spark improves considerably with much easier starting. Unfortunately with either of these timing settings the bike runs poorly with a lot of spitting back & absolutely no power. It will barely pull me away from a standstill even on flat ground. Altering the needle position to its weakest improves matters a small amount but not enough to make the bike ride able. Both needle & main jet are as stipulated.
It would appear that the flywheel is in the wrong position in regard to top dead centre but as it is on a keyway I don't see how it can be unless of course I have a miss match of components.
In addition to this work I would add that I have rebored the barrel & fitted new piston & rings just in case a lack of compression was the problem but this hasn't made a scrap of difference.
Is there anyone out there that can offer any advise on this type of Miller ignition & or solving the problem regarding the lack of power please. Its a shame because the bike is ready to be ridden after its renovation & I would like to have a tootal around the lanes before winter sets in.
