- Tue Aug 20, 2013 9:06 am
#2578
Hi I own a 1998 350 enfield bullet and its an indian built import that came over to the uk in 2000, I have changed all the factory fitted light switches for the 1950s style switches ie, a 3 position bakalite type swich(140844 in hitchcocks catalogue)and a dip horn(lu/315630)I have junked the indiactors,engine cut out switch,and the front brake light switch, so now i have the rock bottom ammount of items that you need to be road legal ie all lights, horn, rear brake light switch,just as bikes used to be with the addition of a boyer ignition(4wires).
I have a wiring diagram but nothing makes any sence as the colours do not tally up and I am less than useless with electrics at the best of times.
can any one tell me where i can get a less than simple wiring diagram that has just the minimal emount of wires that is neede just for ignition,charging,lights that is easy to follow I went on line and found a really siple wiring diagram but it was no fo an enfield it was so easy to follow as it had pictures of each item ie, battery,coil,alternator, lights,distributor,and so on showing where each wire went to, Can any ony please help me with any info to rewire my bike, I have now taken the wiring harness off the bike and unwrapped it so i can reuse the old wires and re,code the colours.
Many many thanks
Regards
Gary (Whitey54)
Many many thanks
Regards
Gary (Whitey54)
