- Tue Jul 09, 2013 6:03 pm
#2405
I've posted a few times before about my lighting problem, well whilst investigating i have found that someone has disconnected the original reg/rect units and fitted a power box at some point. I assumed i could just disconnect the power box and reconnect in the new reg/rect units from hitchcocks...... well i did this and it blew the 20a fuse in the lh side panel. even with the ignition off??
now for starters i cant see this 20a fuse on the wiring diagram, but it appears to have a red wire connected direct to the battery and then has a black wire which goes into the harness and disappears off up to the headlight.
so, is this 20a fuse something to do with the power box? why would the reg/rect unit cause the 20a fuse to blow?
the engine runs with the power box connected but not the reg/rec unit.
please help, i've got the MOT on Friday and was planning on going on a long ride on Sunday!!
Cheers
Ian
Cheers
Ian
