- Sat Jun 22, 2013 2:46 pm
#26042
Hi PAUL------- no need to get too "Technical" with a coil...Assuming you've checked all the other possibilities eg HT plug cap, lead, coil connector, HT supply verified, fuse etc, and with all leads disconnected at the coil, place a jumper wire from the battery POS terminal( assuming it's a NEG earth) direct to the POS terminal on the coil... Identify the wire coming from the distributor ie}--- the points (usually a Black with White stripe)and connect that to the NEG terminal of the coil.......... You now have a "Stand-alone" circuit that will fire the plug if all's well.....with the plug EARTHED, and the points closed, flick the points open and you should get a bright, blue spark and a healthy "crack" sound....NO SPARK at all = coil u/s------- a dull red spark = capacitor u/s...... Bearing in mind that the coil and capacitor were both new at the same time (ie at the factory)then it's a good idea to fit a new capacitor as well....... Personally I have had a "LUCAS" coil fail on me last year, as did a Bullet 65 owning friend as well....I spent the extra and fitted a PVL unit..
