- Sat Jun 22, 2013 12:08 am
#2337
I have a 1935 K model (976cc) which came from the factory with a Model 22 sidecar attached. The appears to be no provision for adjusting the lean out of the bike. The rear lower (to axle) is a fixed point and the top front mounting is the same, although it has an eccentric shaft seemingly allowing tow in adjustment. Then there is a bracing strut that goes between those 2 points. I cant believe there is no way of adjusting the lean angle but neither I nor other sidecar savy people i know can figure this out. I have some photos of the joints I can send to anyone who is willing and able to assist. Thanks David
