- Tue Aug 20, 2013 3:37 pm
#2579
Hello All. I noticed a leak where the exhaust pipe is fixed to the cylinder on my '99 Bullet 500. Not too bad, but a hiss and a bit of backfire on de-celeration. So, I went to remove the exhaust to inspect and had a few issues...and got a few questions.
FIRST, Is the pipe "dry" fitted into the cylinder, or should there be a crush gasket or donut gasket in there to replace? If not, should I be using an exhaust sealing compound to help seal the leak?
QUESTION, am I doing any damage to the valves, etc with this leak...or only suffering a little soot on the pipe?
SECONDLY, IS there a trick to removing the front engine plate nut from the stud bolt? This is where the exhaust pipe bracket mounts and I couldn't get it off. It's a double sided stud and when I begin to remove the right nut, the bolt will turn inside the left nut. I'm trying to prevent removing the entire stud and supporting the engine. Is there a trick to getting this nut off and leaving the stud in?
LASTLY, is it a common issue for the tab to break where the silencer bracket mounts under the tool box? Mine is broken, and the silencer has not been supported. Perhaps this is why the pipe is working itself from the cylinder? I imagine the only remedy is to re-weld the tab back to the frame?
As always, thanks to a wonderful group of enthusiasts...with infinate wisdom!
