- Mon Jun 17, 2013 12:35 pm
#25760
Hi guys-------SOFIASPIN, I can wholeheartedly recommend the 19t sprocket (along with the associated carb jettings, air filter and exhaust. mods)as money well spent, particularly if you are going on long rides..... About 5 or 6 years ago I was running a Bullet 65 which had the Amal carb conversion, the pancake paper air filter, a 19t sprocket and standard "65" silencer.. I rode from TELFORD down to READING, Berks ( 150 miles approx) on mainly A-roads and some dual carriageways averaging a comfortable 55-60mph all the way....My current bike is an Ex-Home market iron engined bike with the same set-up and the same comfortable results........Special tools ?? ... well a clutch locking plate can be made up by welding an old driver and driven plate together,... you can align the generator stator by eyeball,...the primary casing output seal will need to be carefully centred but, again this can be done by eye and a bit of common sense..... I've not found an actual need for any clutch drum mods as yet.... One of the most rewarding mods for comfort has to be changing the fork oil for ATF. Your shoulders will be the main beneficiary of this operation....( And drop the rear shocks by one notch as well--- for balance) ----- finally, why not fit one of our hosts small handlebar windshields ?? keeps that cold draught of your chest and neck.... Hope that's of some help ??---------------------- ps, On the ride to Reading and back it RAINED ALL THE WAY !!--- I got through 3 sets of gloves and two sets of face masks...but averaged approx 80 to 90 MPG...... Ah, bliss !!
