- Fri Aug 16, 2013 7:52 pm
#2563
Been for another ride and what seems a leak - on the l/h side of cylinder head - with some oil on the fins at the level of the spark plug, so above the cylinder head joint. Noticeable on the side opposite to the pushrods.
There seems to be oil on the alu cylinder head on the fins at the level of the spark plug/decompresser/stud at the side. No oil seems to be coming from the oil pipes (and they are on the other side) - the head joint looks 'shiny' but oil isn't seemingly coming from there...and if it was seems odd it would go upwards and make it damp there.
The rocker cover caps aren't leaking either (or damp).
I can't see a 'crack' in the head anywhere....could it come from the stud near the spark plug - is that a normal source of a leak? If so - any suggestions if it is the stud?
M
M
