- Mon May 13, 2013 7:04 pm
#2167
Another problem that I found today, all of the lights are working except the headlight!
The sidelights work, as do the small sidelight in the headlamp, but as soon as you flick it to main headlamp there is nothing. I am sure the actual switch is ok as the rear light and instrument cluster stays lit, and the bulb looks fine and comes on when you 'flash'
So the headlight does not come on even when on full beam, but will come on when flashed. Very confusing. Any tips? Sorry if this does not make much sense
