- Sat May 11, 2013 9:17 pm
#24902
Hey Dennis if you could understand the workings of a sash window or the angles of a roof pitch i would say your over qualified to work on the average enfield.
If the metal plates seem flat and everything seems in order then scrub the plates in paraffin or petrol and reassemble... often improves things as the friction parts get a bit sticky with old oil and wear..
Check the angle of the gear lever as fixed to ensure its movement is compatible with your foot/ankle.
Just moving it a few splines can make a difference...
I'll mention technique, which can help with these constant mesh boxes, When changing down pull the clutch and blip the throttle to bring the engine speed to near gear speed, select gear and hold with the foot untill clutch released and throttle wound back on.. You'll often feel the gear fully engage as the power brought in, if you only dab the gear as in honda it will often bounce into false neutral, the dogs not having time to fully engage the slots and will be thrown out again as torque increased.. If you think about it there has to be a neutral between each gear to prevent two gears being selected at the same time.
Dogs have to clear one gear before engaging the next... Before the nay sayers say they haven't got time for this, remember this is not a racing clutchless teqnique but is used for smooth changes on A/B road riding. cheers gwilly
